Old 02-10-2003, 01:04 PM
alia176 alia176 is offline
Send a message via Yahoo to alia176
Squeeeeek from the right rear
Looking for some ideas on this one. I'm getting a squeak sound coming from the right rear. Goes away when I step on the brake. I removed the caliper and didn't find anything dragging. No, the brake pad wear indicator isn't dragging either. The pads and the rotor are new. Perhaps the leading edge of my pads are making this sound. I should've chamfered the leading edge to see if this goes away. I don't think it's the wheel bearings since they don't have that roar sound I read about on this board.
Thanks for any ideas.
Ali
92
98k miles. Original bearings.
If it ain't broken it, doesn't have enough features!!!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 02-10-2003, 01:37 PM
SHISVX SHISVX is offline
Re: Squeeeeek from the right rear
Ali
92
sometimes the bearing have a squeaky...vibration sound when they first start to go bad, at least that is what my mechanic told me when i took it to the shop the other day for a drive to diagnose this new sound i got in the front wheel well
Kelli
Previous owner of the
Princess Pearlie "Dimples"
as of 8/6/03
1992 LS-L Pearl 124k
"Yeah, that thingy!"
owner of the new 1992 LS-L Pearl "Susie"
I am a pessimistic optimistic. I think the worst is going to happen, that way when it does, i don't feel as bad, but if the best happens, i am twice as happy.
Old 02-10-2003, 02:31 PM
mattski mattski is offline
Or it could be the pad vibrating. Did you use new shims? Some brake pad "glue" might help.
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 02-10-2003, 03:22 PM
I assume my brake pads came with shims so I'm pretty sure I installed them with my brake job. But the wheel bearings going out is a possiblility that I didn't consider.
Thanks for the ideas.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 02-10-2003, 05:37 PM
Rear handbrake
The rear hubs also house the handbrake, which is operated using a cable onto rear shoes in a hub, not the normal extra mechanism pulling on the rear rotors.
If the rear handbrake is sticking on, it might cause this. A way to find out is to pull the handbrake while travelling, and while the squeek is going on. If it changes, then it is the handbrake shoes, cable, whatever.
Old 02-11-2003, 08:50 AM
Another good one. Didn't even think about that one either! I do remember seeing the parking brake stuff while replacing the rear rotors. Thanks. Will check it out this weekend when I return home from Phoenix.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 02-13-2003, 11:43 AM
Best of luck with it alia. Might have worn down a shoe past the rivet, that would squeek.
Also may have dried out with heat, and the shoes are sticking in the on position. If this is the case, use that special bronze coloured hi-temp grease to lubricate[when in doubt] being careful to get none on the shoe faces or the hub rim.
