Old 02-04-2003, 02:08 PM
subafan subafan is offline
not just a fan, a Member!
oil leaks
i'm trying to decide what to do about my leaking svx...
this is what i'm thinking about doing....
since i have no clue what is leaking, i plan to utilize the auto shop coupons i found in the mail this week to 1. tune up the engine and 2. 'winterize' the car (which includes chaning the belts and stuff)
do you guys think this will help me figure out what's leaking and repair it at the same time??
need advice....
Old 02-04-2003, 02:15 PM
92SvxChick
Me too
I can't be of any help in this department. My car is leaking oil and I have checked just about everything and I still can't figure out where it's coming from. It really frusterating!
Megan
Old 02-04-2003, 02:29 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Most likely oil leaks on an SVX are:
Cam Cover gaskets
Front crank seal
Camshaft Seals.
Power Steering O-ring leak is often mistook for an oil leak. It runs down the passenger side front of the engine and by the time it gets down there, looks, feels, and tastes (don't ask, don't try it)like oil.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 02-04-2003, 07:30 PM
Subafreak's Avatar
Subafreak Subafreak is offline
Superbeast
Good point. The Subaru flat motors are easy to find leaks on because, well, it's flat. Take a V or strait motor, if you have oil oil leaking underneath but the motors oily form the valve cover down, it could be any thing else along the way, usually you start with a valve cover gasket, clean the motor and see if it leaks somewere else. With the flat motor it's all layed out so you can tell if its the cam seal, valve cover gasket, or front seal. But that steering pump leak can trick you at first, it's hard to see from the top and looks like a front seal leak from the bottom, but usually the leaks are very easy to pinpoint.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs.
91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch.
78 BRAT (New toy) (Soon to be EJ22T powered)
90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car)
To many cars to spend time on teh web!
Old 02-06-2003, 12:54 AM
DavieGravy DavieGravy is offline
My oil pump leaks a bit, but only when the car is being driven. So this might be a possibility.
Old 02-06-2003, 01:37 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
You should see the puddle I had when I had my PS leak. Now I can tell which is which just by the feel and smell alone. I don't wanna try taste yet.
Now I have a leaky differentials. Saving $$$ for a new SVX or a 5 spd switch. Which ever comes first.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 02-06-2003, 10:07 AM
svx_commuter's Avatar
Cleaning off the engine helps find the problems as Subafreak said. This would be the around the valve covers, oil filler pipe to valve cover, around the timing belt cover, rear side lower back of the engine. Then all you have to do is look for new oil on the engine. I have also used a large piece of cardboard. This can be laid under the car at night. It helps with finding out if it's the front or back of the engine.
