Old 12-04-2002, 04:35 PM
Green1995SVX
AWD Binding weirdness
For the last couple weeks I have had the chance to drive Don (srusvx)'s car as mine is in the shop. His car has awd binding... the weird part is, though, that it is very intermitant. Yesterday, it wouldnt bind at all. This morning it was fine, then this afternoon it started binding again. It comes and goes. What could be the cause of this?
Mike
Old 12-04-2002, 06:34 PM
Pearlywhites1992
Binding
Try doing figure 8's in a parking lot (empty), dunno where I read this was a possible fix, but I did. Good luck!
Old 12-04-2002, 06:43 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Sounds like a partially clogged campaign filter/cooler.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 12-04-2002, 07:33 PM
Ticallion
Experiencing same issue. I don't pay too much attention to it.
Ticallion
Re: Binding
Interesting suggestion. I guess theoretically, it would fix it. I'll try it tomorrow, thanks!!
Old 12-04-2002, 09:33 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Living in denial, eh?
All things, left to themselves, will go from bad to worse.
Driving in figure 8's just allows the transfer clutches more opportunity to slip and wear-in when new or when there's been a lack of lube to the friciton material. If that 'fixes' the problem check, as Doug mentioned, for a clogged external filter or cooler very soon.
Another possibility could be a malfunctioning duty solenoid.
Old 12-05-2002, 04:44 AM
Pearlywhites1992
...especially my two year old! I believe the figure 8's helps
little chunks of material to stick to something magnetic:
maybe the drain plug? I dunno. I did read it, so it must be true!
Just be on the look-out for Tonya Harding thugs, while you're
pirouhetting (sp?)
Old 12-05-2002, 04:12 PM
svx_commuter's Avatar
I agree with Beav. The duty solenoid C is starting fail. There are two little valve spools in this device that are used to control the pressure to the transfer clutches. Those parts have worn and are starting to stick which prevents them from sliding as they should. Duty C can be changed without pulling the tranny. I think the part is about $70.
