Go Back   The Subaru SVX World Network > FAQs, How To's, & Vendors > Vendors, Service, & Parts
Old 01-30-2015, 12:45 AM
ProSport's Avatar
ProSport ProSport is offline
Head Light Replacement
Hi I got this description for the HL replacement from one of the "how to doc's": R/L High Beam Lights 9005
Is this the OEM lights or improved after market part. I have a 92 SVX with extremely weak lights. I can hardly see a thing driving in the dark and I have fairly good eyesight.
Old 01-30-2015, 06:05 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Re: Head Light Replacement
Check the clarity of the lens and use some lens repair if cloudy or yellowing. If you want to stay close to OEM get something like Sylvania SilverStars https://www.sylvania.com/en-us/produ...tar-ultra.aspx of the appropriate size IE 9005.
HIDs are available but are a bit of a wiring chore.
"Peace is the flower of justice."
Old 01-30-2015, 06:30 AM
You can also use high beam bulbs in the low beam sockets with a minor modification of the bulb base.
There's a "How To" doc.
The low beam is a projector type and will not blind oncoming drivers.
Personally I wouldn't bother with the Silverstars. In my experience they give a minor improvement in brightness, are expensive and burn out very quickly.
Old 01-30-2015, 10:00 AM
scoobymal's Avatar
Thumbs up Re: Head Light Replacement
First check what type of bulbs you have fitted, UK, JDM and Europe have H1 and H3 fitments. I fitted HID to mine, was easy, no wires to cut or join.
Old 01-30-2015, 11:36 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
DDM Tuning has Plug and Play HID kits for 9006 (low beam). It only takes about 5 minutes to change the stock bulbs for HID's. Definitely clean up your headlights if they are yellowing, it makes a big difference.
Sam
Old 01-30-2015, 12:34 PM
I agree. Polish the headlights add some sort of protection and put in a DDM tuning HID kit.
Old 01-31-2015, 12:30 PM
ProSport's Avatar
Thanks for all the help guys! Will definitely have to do a cleaning job first!
@Scoobymal, how will I know what type of bulbs I have fitted? Service manual, I suppose?
@Sean486, are these DDM tuning kits available to order online?
Old 01-31-2015, 12:56 PM
gwynethh's Avatar
Sylvania cleaning kit has been good for us and is highly rated. No fancy unnecessary power hardware, just plenty of wet/dry paper, cleaner fluid and clear coat (no we don't work for Sylvania)
HIDs at http://www.ddmtuning.com/Product-Cat...and-Components
