Re: ABS coming on for no reason
Bump......
http://www.svx-iw.com In the Checking Error Codes section of the Svxipedia, it says that 5 blinks of the LED on the ABS control module indicate" Faulty wheel ABS sensor...Left front wheel speed. Procedure for checking the codes can be found there also. .
It's been a while since I did mine but I recall the fronts being much easier than the rears. I also recall that, after replacing one, the result was a new code and the need to replace another one. So be prepared for that.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
I know how to pull the codes, It just doesn't seem clear as to wether it's the ring or the sensor. I also need to know if it's the driver side or pass.
Thread Tools | |
Display Modes | |
