How to remove the cigarette lighter bulb?
We want to replace the green cigarette lighter bulb with a blue LED bulb to go with our illumination change out. It appears the blub is in a socket on the rear of the lighter assembly. (See generic Subaru lighter photo attached, the black nub on the upper right.) The ash try bulb appears similar and it removes by rotating it to release the latching fingers. We can just touch the lighters bulb socket but can't get a good enough hold to rotate it.
Oh by the way, the cigarette light bezel appears even harder to remove with both screws being hidden/inaccessible. So except for a full dash removal any suggestions to get that bulb out? |
Re: How to remove the cigarette lighter bulb?
If you have small hands, it can be done. See this thread and my posts HERE
I have done it a couple of times. I also installed the stamped steel nut backwards so the open edge was facing outwards and not towards the front of the lighter assembly. This makes it easier to grab the edge with a pair of needle-nose pliers. Be sure to let the nut slide back along the power wire and remain there while pulling the assembly out. If you drop it, it is gone forever. .
That will give access to the bulb? If so thanx
Gwyn |
Unless I am mistaken, I thought there was only one bulb that illuminated the outer ring, the inside of the lighter itself AND the portion that shines into the ash tray.
However, the parts diagram seems to indicate 2 bulbs .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 08-11-2014 at 12:10 PM. |
The ash tray one is easy to remove. Still cannot get the lighter assy apart. Will try 90 degree needle nose pliers after vacation.Thanx for the picture.
Yeah, it's a PITA to get at. Pull the radio and it's easy. Great reason to replace the antiquated unit with something modern while getting at the bulb.
