Taillight Issues
Things have started to pop up here and there after the hibernation. Just today I discovered that I had no side rear lights and when braking, the secondary bulb lights do not turn on.
Arrived home (nighttime), turned my lights off, ignition off, and the taillights stayed on Turned the car on, lights on, lights off, nothing still. Did that like 3-4 times, until the taillights are off along with the car. Weird! Note that I was checking the lights after I go out of the car, and not doing the stupid mistake of foot on brake pedal or smthg... What do you guys think?
Re: Taillight Issues
Could you accidentally pressed the parking light switch on the lower dash panel. The switch with the "P" on it.
If depressed, it turns on the parking lights, front and rear side marker lights, tail lights and license plate, regardless of the position of the ignition switch or whether the key is in the ignition or not. .
I know about the P switch John, no that's not it. Part of the taillights (sides in the fenders) are not working. When I push the brake pedal, the secondary lights in the bulbs do not light up either. Really strange...
Have you tested with a meter?
Mine did the same thing a few years ago. I never found the exact cause, but I simply reseated all of the bulbs and it never came back.
Weird electrical gremlins indeed. I'd look for bad grounds and/or bulb oddities such as crossed filaments. They can do strange things to the path the electrons will take.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
Tomorrow is SVX day. I will tackle multiple things and will update you all with the progress.
I have a gut feeling that the lights switch of the steering column is malfunctioning.
Sorry I could not be more help today, I was out helping a kid with his honda.
Its ok Gene.
I just had a very sweet morning. Got into my car, turned the ignition and tick tick tick.... battery is dead. Either i have a bad alternator or a serious electrical drain. Happy me...
Low battery may be causing those electrical gremlins?
Solution turned out to be stupid. The brake light switch above the pedal needed adjustment. The screws were a bit loose (dunno why). I ended up removing the switch, clean it with a spray electronic contact cleaner and adjusting it to the correct position. Problem fixed.
Excellent, free and easy, the best kind of repair.
