Location of fuse 18 ?
remember that I have a RH Drive .... incase it makes a difference.
PS Happy New Year to all.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: Location of fuse 18 ?
Fuse no. 18 is in the fuse box under the instrument panel. Should control cruise, ABS and power steering.
It is on the bottom row In tthe very center (there are 3 rows) 4th fuse in from the left or right. .
thanks for that - fuse is in tact - still the cruise control does not work? - is there a relay in the cruise control supply ? if so where is it located?.
thanks again.
On the LHD cars there is a vac hose that goes from near the battery to the firewall, where there is the cable to the throttle body, if that vac line is old it could be leaking.
If the Cruise Control light in the switch comes on, but it won't engage, the vacuum hose could be disconnected or damaged.
Definitely check the cruise control vacuum hose. It connects to a small black cylindrical modulator, which is attached to the firewall , just to the left of the brake fluid reservoir. Look around in that area for a disconnected small black hose. This is easy to accidentally disconnect (especially if you are checking tranny fluid and most definitely when you are changing the rear plugs. Just find it, plug it back onto the nipple on the right side of the modulator and all should be fine. You can zip-tie it to make it more secure In the photo below, I put mine inside a braided s/s line. Mice had chewed a small hole in my original rubber line, so I had a vacuum leak. I replaced the entire length of hose so it wouldn't happen again. .
Also check the fuse for the horn, I don't know if that is #18. But the horn fuse is with the cruise control.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
Thread Tools | |
Display Modes | |
