Old 12-24-2013, 08:19 PM
ShaneHobson ShaneHobson is offline
Which side is the rear oxygen sensor ?
My 1992 JDM car showed a check engine light a while ago, so I took it to my mechanic to pull the codes.
He advised it was the rear oxygen sensor.
But now that I look at my parts car it seems that both oxygen sensors are side by side, so "rear oxygen sensor" doesn't make sense to me.
Attached is a photo of what I think are the oxygen sensors.
Does anyone know which one is rear vs front ?
Or is there another pair further towards the front that I haven't found ?
I think the sensors lower down in the photo are the oxygen sensors.
Have I got this right ?
I've started another thread asking what are the other two sensors in the photo (higher up the photo, closer to the back of the car).
Thanks, Shane
Old 12-24-2013, 09:34 PM
92 SVX 92 SVX is offline
Re: Which side is the rear oxygen sensor ?
Ok I answered in the other thread but since you say in this one its a 92 I am baffled.
The "rear" o2 sensor is usually the one in or after the cat. The purpose of it is to determine if the cat is working.
Old 12-27-2013, 10:23 AM
Is there a way to text an oxygen sensor to determine if it's working correctly before we fit it ?
Is there a right and wrong way to clean an oxy sensor before fitting it ?
Normally I would have just fitted a new one, but I don't know which one is faulty (or even if it is faulty) and the Subaru dealer wants $600 per sensor (about $US500).
Needless to say SVX parts in NZ are usually privately imported rather than bought from the dealer.
Old 12-27-2013, 12:58 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Youtube has some videos on how to test them. I usually swap the 02 sensors with each other to determine if the trouble code follows before replacing.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
