AAAAGh I broke one
Under the Intake Plenum there are 3 vacuum switches. I have sheered off one of the vacuum ports on 1 switch. It is the switch on the back right side of the assembly. There are no markings on this switch, and it is in a metal sandwich.
Please identify it {picture} and lemme know if it is interchangeable part with any other vehicle. Thanks folks.
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
Re: AAAAGh I broke one
If you can't find a replacement, JB weld works wonders. You could also drill the hole out slightly (and carefully!) and insert a short length of metal tubing and then put a little JB weld around it to seal/hold it in place. I did that when I broke off a similar fitting when replacing my vacuum hoses last fall.
q-bond will fix that thing up. it works better than jb on plastic.
I used super glue on mine after cutting off the bit of hosing it was stuck in.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
I could do that, but I was hoping to find one on another car to pull off intact. Ebay has droves of them, and the Miata Purge Solenoid looks to be the right one by appearance, but I don't want to put something in that goes off at the wrong value.
Similar vintage legacys also used them.
Problem is if you pull another intact one that's the same age it will also be similarly brittle.
Yeah. So, I did the JB Weld fix, and got it back in play.
I have the engine out for the Flexplate, so a few things are getting found, and remedied. But it's a good opportunity to take care of those things without all the monkey work to get to them.
Thread Tools | |
Display Modes | |
