heat/air condition temp
Have a problem maintaining constant temp. While the car is moving, the blower will blow hot air when set to heat and cold air when set to air conditioner but if you stop at a traffic light or in stop/go traffic, the blower will blow ambient temp. air when you stop. As soon as you start moving, the heat or air conditioning will return. Any suggestion as to cause?
Re: heat/air condition temp
Check your coolant level #1
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . |
Coolant level is normal. The coolant temp. is always normal, it's just the temp. of the air that changes when I stop and then it goes back to whatever temp. I've set when I start moving.
Any solution to this? I'm having a similar issue. Air seems to slowly cool the interior (talking about over a long duration, highway driving mostly), nothing impressive like before, but when stopped it warms up noticeably. I have the unfortunate luck of owning a 92 with the R12 refrigerant, so I'm wondering what my options are considering R12 costs are high & I don't have a license to deal with the stuff.
1992 Pearl LS-L : Trans-cooler / ecuTUNE Stage 1 Chip / Pioneer AVIC-U310BT Navigation I hear what you're sayin', but whatta ya mean?! |
Just top it up with r134a, it shouldn't do any damage. My car on the other hand has a leak somewhere so it wont hold refrigerant and im having the dealership go through the car to find and fix it, my dad keeps a little bit of r12 on hand so i can recharge it once its fixed.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
http://www.es-refrigerants.com/produ...it/details.asp
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
R12a refrigerant works well. Compatible with both R12 ans 134, although there is a caveat to drain the old stuff prior to use.. It's available under various brand names.
A word of caution. The leak stop product will destroy a service tech's equipment if it's in the system when evacuated.
I don't mind trying to tackle a challenge here or there, but I'm the village idiot when it comes to refrigerant & don't want to cause any damage to the car
You will end up discharging the system, ( against the lawn to allow it to just go out into the atmosphere ) less you can change the connectors with out loosing coolant. The 12 and 134 are different connectors. Mine was converted and works great. Leaks are usually O rings.
http://www.redtek.com/win_12a_faq.html
Do your fans run?
If you lose a/c cooling at stand still and it works fine when car is moving maybe there's no air flow across the condenser? /T |
Good question. I just bought some r134a, but I'll check this first when I get a chance since I forgot to grab an adapter when I picked up the refrigerant. Thanks for the tip!!
