Bad lifter
I was wondering how can u tell which lifter/bucket is bad? Is there a test or something.
I blew my engine by driving it on old oil... Yes I know what a retard!!!!... So I got another block and put my old heads back on as no valves nor the head was damaged... So I thought... I put the engine altogether then started it and theres a loud and fast tick tick tick sounds like a lifter... The engine runs smooth so I know its not the piston hitting the head.. doubt it is a broken spring. So was just wondering if there was a way to tell which on went bad. Thanks izack
#1 1994 Ls ebony parts car-rip #2 1994 L laguna blue - sold #3 1992 Lsi pearl white - sold #4 1992 Lsi pearl white -Ate two engines - Rip #5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree #6 1992 Lsi custom orange parts car #7 1992 Lsi green 4.44 swap. Currently for sale #8 1992 Lsi custom pearl white. Project car... sold #9 1992 Teal 4.44 swapped... sold #10 1995 Laguna Blue. Sti 19 wheels, #11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂 |
Re: Bad lifter
Re: Bad lifter
When you did you heads, did you remember to insert a screw into the cam gear to lock the lash spring in place when you pulled the camshafts? If you didnt, then you will have a nasty sounding tick from the camshaft slapping around abit caused by the odd lobe configuration. It will not cause any short term damage, but you will have to pull out the camshaft again, reset the spring and re-install. Yeah... Ask me how I found this out.
Re: Bad lifter
Yeah I have driven it around a bit... Yeah I put the valve cove screw in the cam gear. ron told me that one before I started
Re: Bad lifter
are you sure its coming from inside the engine ...
one of my exhuast manifolds is leaking 1 or 2 cylinders and sounds almost like piston slap haha |
Re: Bad lifter
Pull the valve cover on the side you hear it on. Check all lifters that are on the base circle for spring as you push on them with your finger. Rotate the engine as you go and check all lifters as they are on the base circle
Tom |
Re: Bad lifter
and am i looking for any lifters that i can push down on and if they move then that means there bad or the spring is bad??
Re: Bad lifter
Yes base circle is when the cam is not pushing on the lifter.
You would have a miss if the spring or valve were broken. The bad lifter(s) will have play while good ones should be pretty firm against the cam Tom |
Re: Bad lifter
Okay thanks tom I will check that out
