Old 06-18-2012, 05:03 PM
Re: Anyone here currently running with a Borla exhaust?
It's more common than one would think actually. Just about every Subaru will do that. To the average person, could give a bit of a scare though.
Yep. Hondas will actually roll themselves forward in neutral if they're on level ground. Always had to remember to not fully lower them before starting the car after an oil change.
Old 06-18-2012, 05:40 PM
oab_au oab_au is offline
Originally Posted by Subix View Post
It's unfortunate the sound is due to the headers, which means I'll not be able to replicate the sound. Oh well.
The sound of the exhaust that you are trying to get, is due to it being a flat four cylinder engine. The firing order, has the cylinders one one side firing 180* apart, so they overlap, then the other side pair fire 180* so that the sound from one side, blends together to sound like one cylinder. Out the back it sounds like a big twin. Corvairs and Volkswagens sound the same.
The SVX fires cylinders, alternately, one side to the other .
One Arm Bloke.
Tell it like it is!
