Old 05-26-2011, 10:38 AM
Huskymaniac's Avatar
Uses the ignore feature
Boots on struts
Are these supposed float freely, stay up on the strut shaft or stay all the way down on the strut shaft? If they are supposed to stay up or down, what holds them in place?
Tony
Old 06-09-2011, 01:35 PM
Re: Boots on struts
Come on, nobody has an answer for this?
Tony
Old 06-09-2011, 02:49 PM
Re: Boots on struts
mine stay at the top of the strut. it latches onto a ring on the bottom of the bearing plate with teeth on it. you have to rotate it so it can slide over the teeth and then turn a little so it will hang. i don't know if my struts are original but i believe they are b/c i only have 78k on the clock
Old 06-09-2011, 07:12 PM
Old Fogey
Re: Boots on struts
Ya' know, I've done 3 Koni conversions and replacements, and never been able to satisfactorily secure those boots. I was hoping to hear definitive answer, as all the ones I've done they basically self-adjusted position determined by bump-stop position on the strut shaft. 2 of the conversions included new top-mounts (oem), bump-stops and all rubber spring cushioning. I have the FSM's and nothing in the book resolves the issue. I'll admit to
Glenn
