trans compatable?
Will an auto trans from a 97 outback sport wagon bolt into my 92 ls-l? There's a guy selling a reman with papers for 300$ no rear diff though. If it bolts up ill be pumped, but how do i find the trans ratio and how hard would it be to find a matching rear diff any thoughts?
Re: trans compatable?
If you are referring to an Impreza Outback Sport Wagon transmission, than yes it will bolt in, BUT the ratio, (if stock) is 4.11 to 1 and has not been found to be very long lasting behind our bigger engines/heavier cars.
In addition to changing the rear differential, you must NOT use the weaker torque converter and trade out the front speedometer sensor. (#2)
Alright thanks I just figured it was cheap enough to look into as my trans has 180k on it and I'm going to build the spare motor I bought for it some.
Ok found a rebuilt legacy outback trans and again the guy does not know the final drive or have rear diff. Correct me if I was mis informed but I was recently told all automatic awd legacy's in the mid 90s had same final drive? Is this correct and what is nthe ratio?
Grab the code off of the transmission bellhousing and throw it into google. Failing that, there is a transmission chart on my Impreza site, northursalia.com, that will give you all the info for a given tranny code.
Just post the trans # here and make sure it does not have a factory spin on filter on the left side.
This is the ID he gave me # TZ102Z2CBA-BT
http://www.subaru-svx.net/forum/show...ght=TZ102Z2CBA
this should help........G
I thimk ther4 I an, what? huh! 03 Baja. 05 Baja turbo 92legacywagon"snow" 94legacywagon"whinny" 84Brat"huey" 92svx"samantha".pearl 92svx"sabastian"4.44 silver 92svx"sabrina".ebony 05legacy gt limited "Moon" blue. 06 Subaru legacy gt limited. |
Cool beans I'll snag it this week, freshly rebuilt 4.44 should compliment my spare low milege motor nicely, powertrain swap here I come , now just need a rear diff to gut and I'll be golden
Will this trans build on to mt svx?
http://www.laga.se/delinfo.aspx?delindx=47023645 How expensive is it to have a svx trans rebuild? What is it inside that gets damaged? Valves, slides, pump or just every thing? |
