Old 03-04-2010, 10:01 PM
Gamesy's Avatar
Gamesy Gamesy is offline
Transparent paint
Anyone know much about transparent paints? I was thinking about recasting the taillights and removing the amber and am contemplating the best way to color it.
Old 03-05-2010, 07:03 AM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
Re: Transparent paint
Idk if this is what you look for, but it gives a good idea of the product/process involved.
http://www.corrado-club.ca/mods/tailtints.html
Also this can be usefull if you want them red flat (the potato crisps are optional)
http://hondaswap.com/~mike/tails/
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
Old 03-06-2010, 04:14 PM
Gamesy's Avatar
I guess that could work, when the weather gets better i'm gonna try and recast the tail lights without the amber
Old 03-06-2010, 05:13 PM
What do you mean "recast"? I've been thinking about switching the bulb to red and redding out the amber part with some clear red vinyl. In fact, I'm going to order me some red vinyl.
Old 03-06-2010, 05:58 PM
Gamesy's Avatar
i'm gonna make a mold of it and make a new one using polyester casing resin.
so that there wont be the yellow amber section but clear, with a yellow bulb
Old 03-06-2010, 06:33 PM
I actually like this one. Not sure how effective his signals will be under the tint, but it looks good sitting still.
This has unbelievable amounts of fail. If I wanted my tail lights to look that bad I would skip the painting and just go sand blast them.
Old 03-06-2010, 08:58 PM
If this works out well, then you should make some more to sell. Seriously. Also, I think red bulbs would look nicer, and a bit more modern.
Old 03-06-2010, 09:01 PM
Cam Cam is offline
I agree. Just my personal opinion but you should just buff and polish the scratches out and make them look as good as new. I just cleaned and installed some used ones today and they made my car look much cleaner. Totally worth my time.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 03-06-2010, 09:38 PM
Gamesy's Avatar
I need to pick up an extra pair of tail lights so i can still drive around.
Also hopefully tomorrow the first attempt at duplicating the SVX emblem should be cured.
Old 03-06-2010, 11:34 PM
Are you going to do the entire thing clear? And then paint over it in whichever color? Because I would just use the bulbs to provide the color, and leave the lenses clear. Otherwise, paint the inside of the lens. I think it would look better from the outside this way.
Old 03-07-2010, 01:38 AM
Gamesy's Avatar
Ya i'll be painting them on the inside, i was looking into dye's but i would have to make 2 parts to separate the clear from the red. I dont want to leave it clear cause i dont like that "eurolite" or "altezza" look, if you want a clear set i could make you a set if want.
Old 03-07-2010, 10:00 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
+1 if you want the altezza look, you should buy a Neon.
Old 03-08-2010, 08:26 AM
MadMaxSvx's Avatar
Yeah, they look disgusting, but in case of tinting the inner lens in red, the method can be useful.
95´ Subaru SVX EURO
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
69' Mustang Hardtop
Old 03-09-2010, 02:25 AM
Gamesy's Avatar
does anyone know what store sells silicone resin?
Rate This Thread:
