Old 01-17-2010, 09:01 AM
Re: Removal of Crank Pully
Originally Posted by trophy956 View Post
hi ive own and have read the service manual for svx and it never says to rewire the starter ,first the bendex of the starter would just spin ,ive seen nissan starters in subarus from reman companies that the engine in the wrong direction ,now there is a tool that fits in the 4 holes in the crank pulley
it holds the pulleywhile you remove and tighten the bolt ,i use the starter method for 30 years with out breaking anything or causing problems ,one trick is use a ractchet so it doesnt fly up,using the flex plate bolts like a SOHC engine used in the mid 80s is a good method too
crank bolt torque 123 ft lbs
charlie
I was kidding/ being sarcastic!
Old 01-17-2010, 10:15 AM
whtrabbitjoe77 whtrabbitjoe77 is offline
Thanks for all the help guys, I hope by mid week I can get my car on the road
Old 01-17-2010, 10:16 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Old 01-17-2010, 08:51 PM
davew833 davew833 is offline
I've used the breaker bar/bump the starter method a few times on a few different cars and yes, it works, but it's always a little scary. I always try to secure the end of the breaker bar against the passenger side frame rail so it doesn't flail around. Sometimes that works, sometimes it doesn't. Last time I used this technique, the breaker bar got loose, swung around, and sheared off part of the back of my headlight housing. I think the potential of 'collateral damage' of that sort is more of an issue than strain on the starter. There's plenty of other stuff under the hood that can/could get damaged as well, and I certainly wouldn't let anyone else stand anywhere nearby! Don't do it with the hood closed either.
davew833@yahoo.com
Former 6-time SVX owner
Old 01-17-2010, 11:55 PM
kwren's Avatar
kwren kwren is offline
This is totally not dangerous and there is no reason to do it any other way... if you use your head... a "big old breakover bar" and some foam under the end of the "big old breakover bar"
Just lay it on the edge of the fender and crank the engine a tad.
Keith
(be sure to select the correct fender)
Old 01-18-2010, 07:23 AM
Cam Cam is offline
one other way is to take a 2x4 and drilling 5 holes in it. 4 of these will line up with the holes in the pully. you will load studs in these holes to hold the pully in place. the other hole with be centered between the first 4 and you will pass your socket on a small extension through the middle hole. now you can back up the pulley and remove the bolt easily.
