Old 01-04-2010, 11:49 PM
**Ewie**'s Avatar
**Ewie** **Ewie** is offline
Aussie in enemy territory
Ride Height
Just wondering if anyone would have, or know where I can find, the original ride height measurements for a 92 SVX? I'm trying to determine if the rear of my car is lower than it should be due to spring sag... just seems to bottom out with even the slightest load in the trunk. I want to remove the towbar but at the moment it's acting as a bump guard..
Old 01-05-2010, 12:55 PM
Old Fogey
Re: Ride Height
The FSM does spec 5.3 inches minimum clearance at curb weight (unloaded). The Suspension section defines Wheel arch height at the front fender, measured from the exact center of the spindle to the bottom edge of the moulding as 380 mm plus 10 to minus 20mm. Rear, measured at same point; 335mm plus 10 to minus 20mm. They recommend measuring at curb weight, with spare and jack, empty boot and a full tank of fuel, using a thread suspended from the arch to determine the point directly above the spindle center. This is U.S. spec.
Glenn
Old 01-05-2010, 02:40 PM
**Ewie**'s Avatar
Re: Ride Height
Thanks for the info. By "spindle" are you referring to the centre of the hub/wheel?
Old 01-05-2010, 03:05 PM
Old Fogey
Re: Ride Height
Exactly. I suppose just ascertaining precise center of the wheel might suffice, but to be spot-on you would want to pop out the center caps and use the center of the axle spindle.
Glenn
Old 01-05-2010, 06:25 PM
Blacky Blacky is online now
Re: Ride Height
Thanks for the measurements Glenn. The left rear of mine is definately sagging badly. Now I'll know just how much.
Old 01-09-2010, 09:25 PM
alia176 alia176 is offline
Send a message via Yahoo to alia176
Re: Ride Height
I think I'm in the same boat so those #s will help quantify it objectively. So, the question is if our cars are "droopy" do we only have three choices: oem springs or the fancy $$ coil over setup or GC kit?
If it ain't broken it, doesn't have enough features!!!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 01-09-2010, 10:06 PM
Re: Ride Height
RF 365
LF 365
RR 320
LR 295 20mm below minimum spec.
Old 01-10-2010, 04:40 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Ride Height
The 4WS version is 15mm lower at the back than the standard car.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
