Old 11-15-2009, 09:25 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
cold air intake
Out of curiosity, I bought a cone air filter for my SVX. I took out the filter box cover and the filter. I made up a small 3'' PVC pipe with a flange and connected the air filter. When I started the car, all the dash lights would come on and the engine would stall. I put everything back to the original set up and it works fine. Is there something I'm missing? Do I need to make an adjustment with the air flow sensor? I did not have this problem with my Ford pick up when I switched.
Anyone with a "how to" or some photos of a set up?
Old 11-16-2009, 01:05 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: cold air intake
Theres no adjustment that can be made to the airflow meter. \\
It would help to see pics of your setup, but what I believe is happening is that in your install you are having an uneven air current introduced too close to the MAF pickup vane, confusing the ECU. Ideally you should have a length of tubing extending out down into your fenderwell, where the cone filter should be mounted. This way the airflow is stable and even by the time it hits the MAF vane, and you would also be intaking cool air from the fenderwell, NOT the hot air from the engine bay, which will actually make that cone filter REDUCE horespower instead of increasing it.
Old 11-16-2009, 05:46 AM
dannmarr's Avatar
I work for my SVX
Re: cold air intake
Yeah, I just put the cone right after the MAF inside the engine bay. Anyone have pics of their set up?
Old 11-16-2009, 07:44 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: cold air intake
Check out this thread:
http://www.subaru-svx.net/forum/showthread.php?t=41188
The pics at the end of the thread illustrate what im talking about, you should definitely have the cone filter OUTSIDE the engine bay, as with it inside, you are surely running with less HP than even the stock setup. Hot air is less dense air, meaning less HP.
Old 11-16-2009, 01:16 PM
dannmarr's Avatar
I work for my SVX
Re: cold air intake
The first photo is how I had mine set up. The member did say he didn't finish connecting the vacuum hoses and does not say if he had problem in that setup. Is it that I need more distance from the filter and the MAF?
Old 11-16-2009, 01:40 PM
BDSDC BDSDC is offline
Re: cold air intake
Run standard box with a non-oiled filter. I went to a cone filter, and it caused nothing but problems. Fram top of the line filter is oiled and caused havoc with mass air sensor after I removed the cone system. Learned my lesson the hard way and went back to standard set-up. Clean your MAS with MAS Cleaner (autozone has it).
Doc
Old 11-16-2009, 04:08 PM
dromano's Avatar
dromano dromano is offline
Re: cold air intake
Anyone else use white vinegar to clean the MAF?
2012 Outback 3.6R Limited!
Old 12-03-2009, 03:46 PM
dromano's Avatar
Re: cold air intake
I'll take that as a "no".
Old 12-04-2009, 12:47 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Re: cold air intake
I do if need be maybe once a year..
its a mild acid, works great if you need a good
cleaning.
I still use Green oiled filters, love them.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 12-04-2009, 09:42 AM
Green1995SVX's Avatar
Re: cold air intake
There is no reason to use an aftermarket intake setup. The OEM airbox outflows the engine by quite a bit.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 12-04-2009, 10:51 AM
Re: cold air intake
Ive seen no real proof of that..
besides, some people like the look and or sound
the cone offers too.
Danmarr, we have an nice set up that extends the cone
into the fenderwell but keeps it high up enough to be
safe in the rain. It may offer a cooler air intake. I have
some pics if you want.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
