Nailing an Issue... Ball joint Axel,, or Tie rods?
Ok Guys.
Im stumped. I get clanking noise as I turn to the left and only from the left wheel. I only get the noise as I press the gas when I turn. No Gas, No noise as I turn. What do you guys think.\? Thanks in Advance |
Re: Nailing an Issue... Ball joint Axel,, or Tie rods?
CV joint. It's being torqued when under power, not when coasting.
dcb |
Have you had a good look at the suspension? Many years ago I had a low tone rattle/rumble only when I turned in one direction. Put it on a hoist and there was a small boulder about the size of a clenched fist sitting there on the wishbone.
All right...
It was my axel boot and the Lower control arm is shot. Was there not a series on bushings as a set from energy? |
