OEM CD Player
I'm having a weird problem with my CD player and am wondering if anyone else has had it and if there is a fix. When I put a CD into the player, it lights up, says disc, then title and track without any numbers below them. Pretty soon after this, it pops the disc back out and switches back over to the radio. Any ideas? Thanks!
'93 Legacy LS (will last longer than the cockroaches) '94 SVX LSi |
Re: OEM CD Player
Its having trouble reading it. If its a Recordable CD-R, try burning it on the slowest speed possible. If its a store-bought cd, try using a cd laser lens cleaner.
Re: OEM CD Player
Your CD player is probably wearing out. Replace it with one from a 96 or 97 SVX. They have totally different internal components which will not wear out.
Re: OEM CD Player
10 characters.
Re: OEM CD Player
Mine does it as well. Just a problem with older cd players.
Re: OEM CD Player
You might try a CD lens cleaner disc. Relatively cheap fix before giving up on the deck.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
Re: OEM CD Player
The cd player in my '92 played regular and CD-r's just fine for a while. Not long ago it started to have issues skipping and such so I bought a cleaner kit. The cleaning helped for a while but eventually it stopped playing. It would just spit the cd back out burned or not.
I think your player is just getting old. If yours is already rejecting cds getting a cleaner kit probably won't help. Time for a new CD player imo. |
Re: OEM CD Player
essveeexxee-
Sometimes when it is really cold the cd 'fogs up' with condensate in the player and causes errors.
Christian- 96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC. 2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock 1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods 2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock |
