#31
Re: A few questions about my new SVX...
Yup. You know of it?
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle 06 Hyundai Sonata GLS, 77K miles |
#32
However, I don't think that leak would have anything to do with the wandering you're seeing. That just sounds like an alignment issue, unless of course it's the strut-tops or ball joints, but you said things seem solid. For reference, here's the o-ring I'm talking about, it's on the under side of the P/S reservoir:
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty |
#33
i kept looking at the ad wishing i had the money to buy it.
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty - Sold 07/31/2011 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
#34
I'm going to venture to guess tie rod ends and sway bar bushings are in order, along with an alignment.
1991 SVX L JDM |
#35
Okay, one more.
Been reading up quite a lot on the 4EAT and its share of problems, while getting more and more drive time in my car. Didn't think it was anything to worry about at first, but I've noticed a couple things about the way my car shifts. 1. Shift from 1st to 2nd is rather abrupt, accompanied by a thump (not necessarily a noise, more a feeling that the whole car is jerking forward slightly). 2. Seems like it takes a second or two for the tranny to engage when I shift from park to reverse or drive. Aside from that it seems to shift and respond to the throttle just fine. Is this something to worry about, and if so what should I do to adjust/fix it to avoid being forced into my 5mt swap long before I'm prepared for it? (Sorry for the endless stream of questions, everyone has been a great help so far )
#36
The technical service book lists the following as possible causes, listed as usual in order of likelihood: Faulty Control Unit [aka TCU] Valve sticking Faulty 2A accumulator Faulty throttle sensor [aka TPS] Deterioration of ATF Poor engine performance Quote:
Valve sticking Faulty forward clutch relief ball or: Faulty over-running clutch relief ball Forward clutch slippage. The purple colors denote components in the oil pan; can be fixed or assessed without taking off the transmission. The green color denotes components in the rear transfer case;can be fixed or assessed without taking off the transmission. The red color is bad news; if this is your problem you need a rebuild on your transmission. As you are not technical you need to discuss these problems with a transmission specialist who is very good and knows his/her stuff. There are a couple of things you can do, such as checking the TPS is adjusted properly and is not faulty, making sure you have good ATF, and making sure the engine is tuned properly. It is important you attend to these first. Otherwise you could be trying to fix a problem that is not actually there. If you have these three attended to and you still have symptoms, at least you know where to look for a fix. Hope this helps, Joe
