Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
Old 09-21-2008, 10:17 PM
sicksubie's Avatar
auto-x alignments.....
I would like to know what alignment specs people are running for racing. I would like to know the camber/caster ##'s as well as what your suspension height is. I was not able to get an alignment before the auto-x on saturday after installing my coilovers this past week. I was actually running a very small degree of positive camber in the rear. That really hurt me.
Here was what I was thinking... Get it aligned to stock specs at my daily driving height and then at the race lower it slightly giving me negative camber.... Input? Advice?
P.S. looking for advice on tire options as well
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 09-21-2008, 10:27 PM
Re: auto-x alignments.....
Stock specs are quite conservative, only -0.7 or so in the front. Dropping the car an inch isn't going to give you much more that that, probably not past -1.0. Most of the local Subie Auto-xers run at least -2.0 at all four corners here.
Now if you had camber plates in the front it would be a different matter....
*continues thinking about STi coilovers....*
Old 09-22-2008, 07:35 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Bobby,
Stock camber bolts (front only ) will give you a max of ~-1.8 degrees of camber, so use all of it. You'll need to get aftermarket camber bolts for the rear (do a search for the number) and then they'll give you ~-1.5 degrees for the back. Zero degrees of toe works fine (you can play a little here, but I run 0). Stock caster works fine.
-Bill
p.s. yes, camber/caster plates are nice
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-22-2008, 09:02 AM
sicksubie's Avatar
Can I max out my fronts on my own? If so, any tips on an easy way of doing it?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 09-22-2008, 10:05 AM
You could get a camber guage to see what you're setting them to. Someone at Auto-x likely has one.
Old 10-03-2008, 07:45 AM
sicksubie's Avatar
Alignment today... -1.8 in the front, -2 in the rear, 0 toe, stock caster
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-03-2008, 10:36 AM
SVXRide's Avatar
Bobby,
should bring a smile to your face...
-Bill
Old 10-03-2008, 03:18 PM
sicksubie's Avatar
Didnt make it to the alignment shop today... Spent it working the final mounting points on the sparco and wrestling with the intake....
I am about to go try to align my back end tonight. I got aftermarket camber bolts and I am just going to max it out to -2degrees. Question though, do I need two aftermarket bolts per side?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-03-2008, 08:39 PM
SVXRide's Avatar
Bobby,
Yes. One bolt a side will get you to -1.5. You might actually want to try -1.5 out first to see how you like it.
-Bill
Old 10-03-2008, 11:25 PM
sicksubie's Avatar
Top bolt or bottom bolt first?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-04-2008, 08:00 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Doesn't matter. Of course one will go nub in other nub out. Easiest way to get it to the max is to mark the bolt head with a nice white out line (easier to see then the markings on the bolt.
Old 10-04-2008, 08:05 PM
SVXRide's Avatar
If my memory is right, it's the top bolt. I'll take a look tomorrow.
-Bill
Old 10-04-2008, 08:26 PM
benebob's Avatar
-Bill
Both will work though Bill as they're the same side. Front the top is adjustable from factory.
