Re: MAF dead spot?
LOL--i was scared too, but nothing to it. It did fix his.
Re: MAF dead spot?
Aside from the bad coil pack, my hesitation is gone. If yours is missing or broken, I'd definitely replace it. OT knows his stuff when it comes to that.
Re: MAF dead spot?
Do you have the part number for the check valve?
Re: MAF dead spot?
Part No: #16195AA030
http://www.subaru-svx.net/photos/use...svxfiles|24710 Stumbled accross it in svxfile's locker while trying to work out a hesitation issue I'm having. Shame I didn't put it in the right thread...
1992 Onyx SVX 184,500kms Now with new and improved no leak steering! No plants = no life on earth - so go forth and plant green things! |
Re: MAF dead spot?
Chris,
The cam angle cause lossof power and will stop the engine down low. Its the sensor on the head near the battery. If you want you can swap the sensor at the crank over with it and see if the car behaves different. Then you will know one has a problem. You don't need to take the timing cover off. Tony
ECU/TCU relearn periods
Sorry, this is probably another daft newbie question. Not even sure how to phrase it, so hopefully this will make sense. How much would the TCU/ECU relearn time affect any fix tried? e.g. It did take a bit of time after my trans brake band was adjusted for shifts to settle down.
Mine has been to a few shops lately and the battery in and out like a yo-yo and I don't know if she's had enough time in between any of them to do a complete relearn. It isn't that I think its the sole issue for me or anyone else, but I am wondering if it could have implications. So how long does it really take? Is it possible that a fix that doesn't seem to have worked, really could be the right one, if enough relearn time is given? How could you tell the difference? Is there a difference if parts are replaced vs. a simple service? I'm confused. Again!?! (The quote below is from the online CD - page and doc link) Quote:
http://serial.cc/
Re: MAF dead spot?
Alright, ECU bead crush done. The hesitation I have is always worst when the car is cold, so I'm going to leave it till morning and than take it for a test drive. Hopefully things will be sorted out.
Man does that bead ever explode when you squeeze it with the pliers For anyone contemplating doing this mod and worried about it, it's not really that hard. By far the worst part if getting the ECU out of the car and back in when you're done.
Re: MAF dead spot?
Re: MAF dead spot?
IT WORKED!!! Seems that did it. There was no hesitation this morning, and none when I took it for a drive after class. I'm going to give it a couple days to re-learn and make sure it's keeping this up, but at the moment it seems to be fixed.
Re: MAF dead spot?
Cool, glad to hear it. I'll try it on mine, and hopefully I will get dancing bananas too.
Re: MAF dead spot?
I have had the same issue on mine for about a year...
Only does it when the engine is cold (outside temp doesn't seem to matter) and its definitely intermittent. Being a 94, mine doesn't have an "ECU bead" to crush - correct? Has anyone had any luck with replacing the IRIS/TPS? It seems everytime I hear of this problem, crushing the ECU bead fixes it... lucky people with '92's!
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
Re: MAF dead spot?
The TPS was the first thing I tried to fix it. That was a $250 shot in the dark that didn't get me anywhere. I had OT check it and tune it to spec at Reading with his Select Monitor and still no dice there. I've seen the IRIS check valve mentioned as a possible cause/solution. It's cheap and seems easy enough to change.
#28
Re: ECU/TCU relearn periods
Put car in park. Turn on car. Leave on for 10 minutes or until warm (leave car in park and don't turn on the A/C or anything). Turn car off. I figured that a similar relearn procedure would work for any OBDI SVX 1992-1995. I don't know if that's the case though. I've tried it with my own car and I can't really tell.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi Last edited by Manarius; 10-02-2008 at 12:37 PM. |
#29
Re: MAF dead spot?
Update: After a day and a half worth of my daily routine, still smooth as buttah. This includes this morning, which was below freezing. (had to bust out the credit card to scrape frost off the car)
