#31
Never have had to before. Also have never had to grease the coil boots either. Before this car, I had a 91 Legacy which had a central coil.
#32
Tom |
#33
I made every coil look like this picture: . And every coil wire looks like this:
#34
#35
Did you try to isolate it to one cylinder yet?
#36
I haven't tried that yet. Matt suggested pulling the injector wires. A good idea?
#37
Are you taking it to Carlisle?
#38
Definitely. My cousin is graduating tomorrow, so I won't be able to be there until later Saturday evening. I also won't be able to come up until the afternoon on Sunday.
#39
This case may be closed. Hocrest noted at the show on Saturday that a leaking exhaust may be causing the problems I have. So, I filled the exhaust crack today and immediately the ECU threw a code 22 for knock sensor. I picked up a sensor and pulled out the old one and it was all cracked up. That may be the answer to my problem after all.
Said knock sensor:
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi Last edited by Manarius; 05-19-2008 at 06:21 PM. |
#40
I hope that is it, but when I changed my knock sensors a few years back as PM they both looked like that. Car was running fine.
