Old 01-05-2008, 01:21 PM
nmbutter73 nmbutter73 is offline
valve cover gasket
Ok, need more advice, How hard is it to replace the valve cover gaskets on these engines? Is this engine a "boxer" engine, and are they located underneath the engine?
Thanks again
Old 01-05-2008, 01:23 PM
redlightningsvx's Avatar
Collision Refinishing Tech
they are located on the sides of the motor, where the spark plugs are
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-05-2008, 01:50 PM
And yes, it is a "boxer" engine.
Old 01-05-2008, 04:42 PM
gsodonis's Avatar
gsodonis gsodonis is offline
Gaskets
Thanks again
I just replaced mine. There's a how-to document that's very detailed and helpful. Do yourself a favor and tilt the engine in the engine bay (one side at a time) to get a good bit more room to work. It only takes the removal of the nut that holds the motor mount to the crossmember and a hydraulic jack with some wood blocks under the oil pan (again, one side at a time).
Old 04-03-2008, 01:38 PM
hawaii-svx hawaii-svx is offline
I have looked through the how-to doc's and cant find the write up can someone link it please
