Old 10-14-2007, 02:18 AM
Dessertrunner's Avatar
Okay wheels fitted, took it for a 1500k run everything was good. Need to install back panels and inside wheel well covers and the job is complete. The handling wasn't as badly effected as I thought with the raising of the car by 50mm higher as the tyres are larger Dia and wider which increased the foot print. The car height is now 102mm higher, 135mm standard, 50mm extra from DMS and 52mm from the Wrangler tyres, total clearance 237mm or close to 5in.
Here are the pictures and it looks like its all tyre in real life.
Tony
Old 10-14-2007, 03:26 AM
Trevor's Avatar
Trevor Trevor is offline
Originally Posted by Trevor View Post
Tony, Please, please, please,
Write up an article for publishing here. It will definitely comprise the most important FAQ on offer.
If you are short on time, simply bash out a series of facts and experiences, send me a PM or email and I will be happy to knock something into shape. Final publishing would be subject to your consent and copy rights remain your property.
This is important and very much a worthwhile project.
Thanks in advance as I are sure you will come to the party.
Sincerely, Trevor.
P.S. How about some photographs.
Tony, bumpy, bumpsy, bump.
Trevor, New Zealand.
Old 10-14-2007, 12:10 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool bigger wheels on a stock car
Trevor - looking at changing my tires from the stock 50 series 17" to a 55 series 17" (giving me approx 20mm more clearance) - do you see any issues with doing this, I know that speedo will be out, but I use GPS for speed anyway so that is not an issue.
As for the gearbox changes / diff issues, I don't think that the diffs will be a problem because all 4 wheels will be the same dia.
Old 10-14-2007, 03:18 PM
What width tyre as we can use a Tyre size calculator to check it out for you.
Tony
Old 10-14-2007, 03:43 PM
Holy cow, and my friends gave me grief over my meaty Blizzaks, I gotta show them this.
So what is that kevlar supposed to do?
Old 10-14-2007, 06:30 PM
Kevlar is tough, as in bullet-proof vest use.
It is a help to save the sidewalls from getting cut by stones.
Old 10-14-2007, 06:53 PM
Also these tyres have a bigger side wall which should also help with the corrigations in the road. With the kevlar in the tyre I can run at a lower pressure which should help with vibrations from the road. On a rough road at speed its real hard to keep the tyre in contact with the ground. If the pressure is to high and the spring to soft the wheel just bounces and you have totally no control.
Tony
Display Modes
