Old 09-05-2005, 12:53 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
Question water in trunk!
well, i got in my trunk yesterday and opened up where my spare is and there was a bunch of water laying around on the floor. it wasn't a huge amount,but i've never seen water in there before so wtf?! any ideas on how to figure out where it's coming from?
Old 09-05-2005, 12:59 PM
Subafreak's Avatar
Superbeast
Should be another easy one. Do you have tail light condensation? If so take out the tail lights and seal the gasket "both sides to be safe" with some regular RTV, clear or black. This should take care of both problems. If you still have a leak you might want to seal the large plastic plug below the tail lights, Ive seen thatr leak to.
Old 09-05-2005, 05:18 PM
immortal_suby's Avatar
Thread Killah
Also check the power antenna drain and sunroof drain pipes
Locker Link
2015 BRZ Limited 6MT
Old 09-05-2005, 06:25 PM
Budfreak's Avatar
Banned
Thumbs up
i do have taillight condensation so i'll check that out tommorrow. i'll check those drains too. thanks guys!
Old 09-06-2005, 10:11 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Some Svxer's used to have that problem with water in the trunk. So you're not the only one
Wash your car and see what happens. I'm guessing tail light seals.
1995 Subaru Svx L / AWD
Old 09-06-2005, 01:55 PM
94svxred 94svxred is offline
I remember someone else posted they had water in the trunk due to the seal leaking around the main deck lid maybe you can do a serach good luck!
Old 09-06-2005, 02:36 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Double thanks, found water in my car's lower trunk area. No tail light condensation though. Trunk seal looks fine, upper area dry, will check those antenne and sunroof drains.
Gene and Ben
Old 09-06-2005, 03:01 PM
Earthworm's Avatar
Meow!
I wouldn't put silicone on both sides of the gasket as you'll never ever get them off the car again.
Old 09-06-2005, 04:50 PM
crimsonnblue
Well,
I thought I was the only one.... Um I get water in my trunk, and my left rear tailight gets condensation...
Whats the easiest way to fix both?? silicone?
Old 09-06-2005, 04:53 PM
Budfreak's Avatar
Banned
Originally Posted by crimsonnblue
Well,
mine is the same way too. i get very little condensation in the right light but plenty in the left. i've had that problem since i got it but never had water in the trunk till now though. didn't have time to look at it today but i will tomorrow.
Old 09-07-2005, 04:56 PM
crimsonnblue
I recentlyjust got this car and Well I noticed the condensation. What is the best thing to use to seal the tailight. And trunck.
Do I need to pull out the taillight assembly.
What exactly is making water leak into the trunk?
Old 09-07-2005, 05:22 PM
Earthworm's Avatar
Meow!
Water gets in the trunk between the taillight<->gasket<->body.
I put silicone between the taillight and gasket then grease between the gasket and body to stop the condensation in the taillight and water in trunk.
Old 09-08-2005, 03:25 PM
crimsonnblue
Sweet Thanx
Old 08-24-2007, 06:33 PM
NiftySVX NiftySVX is offline
Water in my trunk?
I Just noticed water in my trunk. I think it may be from the main seal. It rained here really hard. I don't think it was coming from the tail light area, because the rear carpet and masonite board were wet on the left side. Anyone seen this before? This car doesn't have a sunroof, so i know it's not that.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 08-24-2007, 06:44 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I had a similar thing happen to me. when i bought the car there would be condensation in it every morning! there would also be a puddle of water in the trunk. the culprit was the pas. side tail light, it would leak behind the seal so i siliconed all the rear lights and no more water yours sounds light it might be the seal that goes around the trunk or the rear panel light on the trunk. try sealing the gasket and it might work.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
