Old 04-21-2007, 05:07 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
Checking Timing Belt Marks???
I suspect that the SVX has a jumped timing. After open up the timing cover, I couldnt see any timing mark on the belt, they must faded away!
Anyway, how can I tell if the timing belt has jumped?
Thanks
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 04-21-2007, 05:44 PM
cdvs cdvs is offline
Did you rotate the engine to make sure they aren't in the wrong position to see them?
Old 04-21-2007, 05:48 PM
pearlm30's Avatar
Yes, I rotate the engine using the crank pulley, I can see timing marks, but nothing on the belt(faded away).
Basically, how can I tell if I have a jumped timing without marks on the belt???
Old 04-21-2007, 06:03 PM
There are 53 teeth on the belt between both of the cam marks and the crank mark. Is this enough for you?
Old 04-22-2007, 12:58 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
If you still have the rear belt covers in place, there is a ridge in the plastic that lines up with each cam pulley mark.
When the mark on the crank is at 12 o'clock, The Right cam pulley will have the mark at about 10 o'clock and the left will be at about 2 o'clock.
Old 04-22-2007, 11:17 PM
pearlm30's Avatar
OK, looks like it line up with the marks, but not perfectly(half tooth off???). Got the OEM timing belt from thumper_svx(great help) and will install the OEM timing belt tomorrow. Will report back.
Old 04-23-2007, 12:05 PM
thumper_svx's Avatar
thumper_svx thumper_svx is offline
Either committed, or should be
Send a message via ICQ to thumper_svx Send a message via Yahoo to thumper_svx
Heh... you're welcome, mate. I had two of 'em! Thanks for your help, also... it's still helping me to narrow down my issues. OK... maybe just the issues with my car...
YOU'VE GOT A SLIPPED MARK!!!!
Seriously, no... you're probably seeing a slight "misprint" of the lines on the timing belt. So long as all the marks seems off by the same amount in the same direction it's probably just a slight manufacturing defect. I've seen that a few times.
Ich bin ein SVXer wieder
My Rides:
Red 1996 SVX LSi (Saffron)
2007 Yamaha FJR1300 (Kaitlin)
Previously owned; green '95 L AWD (sold), black/pearlie '94 LSi (too many problems), Polo Green '96 SVX LSi (apparently notThe end of an era)
Member #2 in the Yahoo! club, been here since the beta-testing days. In dire need of a cheaper hobby.
