ABS thingie that fastens to front wheel hub???
How do I disconect it so I can take the hub to a machine shop and get a new bearing pressed in?? Please don't say to take the bolt out.
I did that mbut it is stuck worse than you can imagine. Rust buster or something?? Please give me a clue if you have a good idea! Thanks, Keith |
Soak it in PB Blaster repeatedly. Once it's soaked for a day use a drift to tap on the tab where the bolt went through to rotate it back and forth. Once you've rotated it a few times you should be able to get it out.
