Old 03-02-2007, 11:12 AM
RalphSVX RalphSVX is offline
recommend lucas stop slip?
I was thinking of adding the lucas stop slip into the tranny but should I first change the fluid or can I just add the lucas stuff.
Old 03-02-2007, 11:30 AM
DarknessofDeath's Avatar
DarknessofDeath DarknessofDeath is offline
Inhabitant of Darkness
i just add a little in. but make sure you check the levels...you shoud keep the levels in specs
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 03-02-2007, 04:41 PM
I would check the fluid. It depends on what the fluid is like. If is smells burnt, I would change some and then add your stuff.
Old 03-02-2007, 05:35 PM
A) Are you having a problem?
B) You can never change out the trans fluid too much.
C) Unless you power flush a transmission, you can never change the tranny fluid too often!
Old 03-02-2007, 09:58 PM
forgot to say, i dont notice anything with it, but i use it as it is - an additive
