Old 12-31-2006, 07:57 AM
disbo disbo is offline
Question Leaking Power steering question
Hi Folks, I have a 94 with a 5 speed and Ive noticed that Im losing power steering fluid (I have to refill it about once every 3-4 weeks). I dont see any around the recepticle but I do see some from the steering rack.
Is this a common problem? Im not that excited about replacing the pump or the arm
Is there any product on the market that may help seal up this slow leak? I know there is some items like that for oil leaks.
Thanks Chris
Old 12-31-2006, 03:29 PM
If the hoses have not been replaced in the past, you might check them carefully. The pressure side or return lines are the most comon ones to go.
Old 01-01-2007, 11:20 AM
PS leak
Thanks. Ill check them out. Ill have to see where the leak is coming from though... thanks Chris
Old 01-01-2007, 01:37 PM
The steering rack does seem to leak from time to time. Good luck.
