Looks like similar results from the hyper ground kits on the market - which multiple car mags have shown the results to be real from their own dyno tests. Modern electronics just love a solid state of power/ground (pun intended )
-Bill
I have a 1F capacitor I had installed when I installed my stereo. I didn't notice any difference as to how my car ran. The car still eats alternators on average of one rebuild per year.
I brought this subject up in December of last year (voltage stabilizer). This is the response I got from AFBeefcake;
Its just a capacitor of around .5 farads. Yes a capacitor will stabilize the voltage, but unless your running subs and amps, You really would not need one. A capacitor resists voltage change. As the voltage across the cap drops the cap tries to make up for the difference by suppling voltage. The bigger the cap the longer it can make up of the difference in voltage. once the voltage across the cap is back to normal the cap recharges. A capacitor really only helps when voltage draw is continually changing. Like with a sub woofer amp, when the sub hits is draws power. The harder the hit the more power drawn. Last edited by dannmarr; 10-07-2006 at 07:21 PM. |
Yes this is correct and a usefull application which makes sense, particularly if there is an unusually long supply cable run, of limited cross section, e.g. battery to trunk.
An audio amplifier will draw high current at high sound peaks in the signal and the resistance in the supply leads will result in voltage drop. Fluctuations will be of a very short duration and therefor a large capacitor is capable of "filling in" such short depressions in the supply voltage. That said, if the supply line is adequate, an extra capacitor will serve no purpose. Any amp of sound design will incorporate existing built in capacitors, to cater for what can be considered normal. The same theory can of course be dishonestly claimed in respect of the ignition system, but the same conditions do not apply and the sales pitch made is invalid. Looks good, a talking point, fun to fit, costs you, surely must feel/work better.
It would however be interesting to see if it had any effect on components like the sunroof, windows and antenna. It seems as though these items don't receive adequate/consistant voltage.
If you are experiencing trouble in this regard, fix the fault, which will be resistance in the respective supply line.
