Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Turbo Projects
Old 10-01-2006, 10:34 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Send a message via AIM to Stevebsy Send a message via Yahoo to Stevebsy
Exhaust manifold adapting/fabricating for turbo conversion...
Thinking too much today...
Anyhoo. Should I be able to adapt something like this, (EJ20/22 Turbo exhaust manifold/header):
http://cgi.ebay.com/ebaymotors/Subar...QQcmdZViewItem
for the SVX, by adding the third tube on each side, and merging it into one of the other pipes from the same side of the engine? So that the 1/3 and 4/6 would 'share' the same pipe to the turbo.
Will it put the turbo in the right place for the EG33?
Or should I just start from scratch if I go turbo?
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway!
'20 Honda Ridgeline
Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here:
http://www.x35design.com
Old 10-02-2006, 03:17 PM
cdigerlando cdigerlando is offline
Turbo Dreams
I think if I had it all to do over again I would do twins located in the front bumpers. Problem is finding a custom bumper to fit them......no wait......your the bumper guy! I think that would be a nice setup. Take cold air directly from front vents, like porsche. Run directly to a two opening front mount. Cut the crap out of the bumper and run true twin intakes back to the manifold. You could match them at the intake so they have balance.
Back to the upipe. Running three pipes directly to the up-pipe connection of the turbo would probably give you the best turbo response.
Just think about getting the turbos high enough so that oil can gravity freely to the pan. You are going to need to install a filter sandwitch for oil to the turbos. While your at it you should do an oil cooler. Then if you want to do something about engine management, you should see if LAN can tune your car for you. You could start out with with his stage 3 map. You will also need some fuel injectors. You could go with stock 95' 96' Nissan 300 zx turbo injectors or the Q85 injectors (same thing).
What are you doing about your tranny?
Have fun
Chuck D.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 10-02-2006, 06:04 PM
Stevebsy's Avatar
Administrator
Decisions decisions...
I suppose there are a lot of ways to make this happen..I'll just have to take a closer look at it all. I still have my GM 3800 Supercharger sitting around too, so I could go that route...
I think putting them in the bumper area will require an extra sump pump for the drain oil, but they are available out there.
Then management..I think I'd probably go w/ the megasquirt, as I already made one for my former XT turbo. It can run ignition and fuel. I'd leave the factory ECU to run all the other stuff though.
I think I'll just run the 4.444 4EAT until it blows up, then get another one, or go 5/6 mt.
Oh well back to thinking....
Have fun
Chuck D.
'20 Honda Ridgeline
Old 10-02-2006, 06:24 PM
[QUOTE=Stevebsy]I'd leave the factory ECU to run all the other stuff though.
/QUOTE]
Bad idea. You need to change the timing maps. You should follow my thread on timing and look at page 42 under the supercharger section. The car needs more timing to run boost or the EGTs go through the roof. Go figure. Read up and let me know what you think.
Chuck D.
Old 10-02-2006, 10:39 PM
Stevebsy's Avatar
Administrator
Not a problem, the new version of the Megasquirt can control ignition and fuel, so the factory ECU will just run the cruise, wipers, fans, etc.. non-engine stuff.
[QUOTE=cdigerlando]
/QUOTE]
'20 Honda Ridgeline
Old 10-03-2006, 05:33 AM
Phast SVX's Avatar
Phast SVX Phast SVX is offline
BOOOOOOOOOOOOOOOOOST
Send a message via AIM to Phast SVX
There is no way that manifold will work. Its not where you need to be, not even close. its ground up or nothing.
phil
~Phil
Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog.
Old 10-03-2006, 09:07 AM
Ground up.
phil
What do you mean?
Chuck D.
Old 10-03-2006, 12:16 PM
start from the ground(point zero) and work your way up... Just using a phrase to start from scratch
tom
Old 10-03-2006, 04:10 PM
tom
I see what you mean. Yes. Ground up is better. Sorry. I was pretty tired.
Chuck D.
Rate This Thread:
