Old 08-24-2006, 11:22 PM
AJ4U2's Avatar
AJ4U2 AJ4U2 is offline
Front Struts
Is there a aftermaket replacement for the struts mounts for the svx or is the only ones will fit is from a subaru parts house. I believe mind are gone for when i go over a crack in the road it has a pretty hefty clunk in the front. i did jack it up and did not see any thing else wrong in the steering part. sway bar bushing seems ok and ball joints so i guess that part is what is wrong with them. And are they a bummer to replace if that is what is wrong.
Thanks Art
Old 08-28-2006, 10:59 PM
mbtoloczko's Avatar
sans SVX
OEM mounts are the only current option. SVXRide is working on a set of pillowball mounts, but they will be more noisy than the worn out OEM mounts.
Mychailo
Visit my locker
Old 08-29-2006, 04:42 PM
Yoda3000's Avatar
Yoda3000 Yoda3000 is offline
(This account is in rememberance of)Duct Tape Man
Send a message via AIM to Yoda3000
Koni is the only one that makes aftermarket strut inserts that fit the SVX. They cost around $650 for four and require a little bit of cutting of the stock strut housing to install. I really want to buy them but don't want to spend the cash right now.
Early deceased SVXWN Member
July 1986 -- February 2007
Michael - Duct Tape Man
1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit
1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something.
"It's only after we've lost everything that we're free to do anything" - Fight Club
"This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X
