Old 08-06-2006, 06:15 PM
demonsvx's Avatar
demonsvx demonsvx is offline
building more AK47's
Easiest way to drain gas tank?
Anyone got any ideas on how to drain the gas tank?
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT
Old 08-06-2006, 08:40 PM
Sr240sx's Avatar
Sr240sx Sr240sx is offline
I took out the fuel sending unit and siphoned it through said hole.
My '95 SR20DET powered 240sx track car.
http://www.cardomain.com/ride/2161953
Old 08-06-2006, 08:43 PM
It's Just Eric's Avatar
Missing in action
Drill a hole in the bottom
Unless of course you plan on using the tank again, then go with the other thing
R.I.P Cool Signature.
Old 08-06-2006, 09:34 PM
Trevor's Avatar
Trevor Trevor is offline
Two holes The interesting thing in all this is that in two places, the manual says simply, "drain the tank", no mention of how, Perhaps they are suggesting one should invert the car over a bucket. True, because I checked in the hope of being of some assitance.
Trevor, New Zealand.
Old 08-06-2006, 09:51 PM
Manarius's Avatar
Manarius Manarius is offline
Drive it around until you run out of gas?
-Jason
-Obi Wan Kenobi
Old 08-07-2006, 02:02 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I had to drain mine after picking up 4.5 gallons of dark-yellow non-flammable "petrol"
I undid the hose that runs from the fuel filter to the injector rail and put it into a 2 Litre lemonade bottle. When you turn on the ignition you get a 10 second burst of fuel through the pipe then it stops. So you just cycle the ignition switch a few times then empty the bottle and start again. It took an hour or so to drain that much "fuel".
After draining it I put in a tank of good fuel, but there must have been a little of the bad stuff left because I was getting rough running and codes from the knock sensors. But that went away after a couple of fill ups.
Phil.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-07-2006, 11:05 AM
Marcus Marcus is offline
use a hose
Hi,
if you want to keep it really easy and do not care wether a little bit of gas is left in the tank use a hose (from Wal Mart) with a little rubber made hand pump (just because you do not want to suck by yourself), place the long end in the tank and the other in a bin/bottle/canister staying on the ground (need to be on lower level than tank). As soon as the hose is filled, a steady flow will result.
Be carefull not to overfill your cannister.
Good luck!
PS: If you put the wrong gas in the tank dilute the remaining amount with the right gas and repeat the procedure instead of running the mixture thru the engine.
Old 08-07-2006, 03:36 PM
Yoda3000's Avatar
Yoda3000 Yoda3000 is offline
(This account is in rememberance of)Duct Tape Man
Send a message via AIM to Yoda3000
you can't fit a hose down into the tank to get it out. There's a one-way type door in there before it gets into the tank. You could pump the gas out (like the guy above suggested) from the fuel pump door (under the carpet behind the rear sets) Good luck!
Early deceased SVXWN Member
July 1986 -- February 2007
Michael - Duct Tape Man
1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit
1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something.
"It's only after we've lost everything that we're free to do anything" - Fight Club
"This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X
