Old 05-08-2006, 09:08 PM
Trevor's Avatar
Trevor Trevor is offline
Originally Posted by TomsSVX
Ok, finally got it up in the air tonight and did aquickl test. Turns out that my sol. C is working and it is working properly. With the ignition on/engine off, when I hit the throttle, I can hear the sol. cycling. As I open the throttle, the solenoid cycles less and less until it doesn't cycle anymore at/close to WOT. So, Why the hell am I having a binding issue and why is the Sol C code comming up?
Reference your message in another thread. I do not hide behind an alias and am pleased to provide my phone number and address. Trevor R. Sheffield, 16A Seaside Avenue, Waterview, Auckland, 1007, New Zealand. (nz) 09-8208553
However please hold off phoning until I have had time to mull over your dilemma and I will come back here, or by PM. Meantime my thought is that the valve could have something preventing full travel, e.g. on the seat, but could still be moving enough to be audible. What do you think ?
Trevor, New Zealand.
Old 05-08-2006, 10:15 PM
its a good possibility that is the case but it still boggles my mind. The battery in the car is dead right now because I don't have the time or spare cash to throw at this car right now. I will get a jump pack tomorrow and jump it again and see if it is possibly fixed. I was fiddling around with the harness before I did the test so maybe I cleared up a bad connection i don't know
Edit: Damn, you are in New Zealand, sorry man but those charges would kill my phone bill, thanks though
Old 05-13-2006, 12:19 PM
Well, thanks to SVXfiles, I have installed a whole new tailshaft. The FWD lights comes on now. I have yet to take it down off the jackstands but it is family time now. I will take it for a spin tomorrow or later on tonight when I take it down
Old 05-15-2006, 11:30 AM
It's ALIVE!!!! The new tailshaft has fixed all ailments. My guess is that there was an abstruction of the transfer valve in the old housing which would not allow it to actually cut the line pressure. I know the Sol. C was working but the transfer valve was not. So all in all it was a good day Now I need to go get it registered and try to get it passed by the inspection o Joisey. Anyway, thank you all who helped, this car is now running well and I am very grateful since I amy decide to blow up my silver one soon
Old 05-15-2006, 11:40 AM
Originally Posted by Manarius
Oh come on Thawa, you know as well as I do that when the AWD binds, 9 times out of 10 it's torquebind. Don't get smart with me. Torquebind isn't clutches sticking.
Source: http://legacycentral.org/library/torquebind.htm
I'm with Thawa, the 4EAT doesn't have a "Center Diff" just a clutch pack that feeds power to the rear diff, directly split off the main shaft.
Old 05-15-2006, 04:01 PM
oab_au oab_au is offline
Tom, are you binding on sharp/slow corners? This would make me lean much more towards the center diff. Over time, the 4EAT's will start to torquebind, and the source of this binding is the center diff (hence why when you put in the AWD fuse, nothing changes because the center diff is still powering the front wheels).
If you let this go, eventually you'll shear all the teeth from your center diff and you'll have a car that won't move.
I liked this one better Huck, we have a center diff with teeth, and a AWD fuse.
One Arm Bloke.
Tell it like it is!
Old 05-15-2006, 05:11 PM
intelisevil's Avatar
intelisevil intelisevil is offline
<<<Alcyone
Be nice . . . Some of us are still learning!
Dan
Old 05-15-2006, 05:51 PM
actually he is probobly refering to the stage 2 4eat in the more current Subies. Don't trash what you don't know
Old 05-15-2006, 06:39 PM
Trevor's Avatar
Dan
Courtesy applauded. All usually learn from their mstakes. However it is confirmed that there are the odd ones out.
