thats what I wanted... someone with a good understanding of the system to confirm the elusive suspiscion thats all. I don't need someone random saying..."Yeah thats how it works," and sending me down the wrong path. Thanks to those of you with valuable input
Tom |
how to diagnose the solenoid http://www.main.experiencetherave.co..._sol_diag1.jpg http://www.main.experiencetherave.co..._sol_diag2.jpg and here is how it operates http://www.main.experiencetherave.co...er_system1.jpg http://www.main.experiencetherave.co...er_system2.jpg http://www.main.experiencetherave.co...er_system3.jpg nipper |
thanks, this factual evidence is what I was looking for. Getting a little tired of assumptions
Tom |
You and me both. But I have disconnected the wire to solenoid C from the TCU causing 0.0v and also causing 4wd, and binding in corners. My car wouldnt go into 4wd. I believe now it had something to do with the tcu. I had to find all this info already, only when I tried to find out everyone said this or that and it all contradicted. I finally just went off my FSM for my xt6 and the 4eat in the xt6 is nearly the same(nearly). So now that you know you could check at the tcu and the connection at the tranny.( There is a PDF file in username LEE's personal locker it shows where all the wires are and there function on the tcu and at the connector) To see if it is working. and if everything is working outside of the tranny then you would have to crack open the rear end and check at the solenoid. I posted the other thing about the valve system as harvey posted it for me a while back. Although as I said I didnt have to go that far as it actually wasnt a mechanical problem. I hate to say this but if I had to guess I would say that either your solenoid is in fact dead in water, or the wire at the solenoid might have been pulled apart or pinched when put back together. just a guess but I would say that's probably it. Also I speak for myself but I believe people say I think and I believe because not everyone (most no one) wants to be liable if there wrong and you screw something up and get angry. No one wants you to come back on here saying its there fault. Thats why I believe you should invest in a FSM. I know they cost a bit but think of all that you will be able to know just by opening a book. not to mention how much you will save from not breaking something to find out how it works. Also if you have mitchell on demand CD for the SVX (thats what I got) there is a wiring diagram under table of contents/system wiring diagram/transmission Anyways just my 2 cents as everyone says on here.
1989 Subaru XT6 130k 1992 Subaru SVX 120k 1993 Ford Probe 30mpg 213k 1989 Subaru XT6 150k All good and running Last edited by spinn360; 05-01-2006 at 09:18 PM. |
I do have the Mitchell disks. Infact I have about 30 copies of them. I only use it to troubleshoot wiring and for torque specs and sequencing. For something like this, Mitchell cd's are useless and if this has not been discussed before, it should be anyway. Thanks for the replies, once finals are done at school I will get into the teal
Tom |
Sincerely, Trevor.
Thread Tools | |
Display Modes | |
