Old 04-29-2006, 11:38 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
Buzzzzzzzzzzzzzzz SHUT UP!
Ok im getting the 1900 RPM buzz from the secondary cat... is there any other solution then replacing it? can i hammer the h. e. double hockey stick out of it? or drill some holes? (yeah i know it probobly wouldnt work)
Old 04-29-2006, 12:53 PM
intelisevil's Avatar
intelisevil intelisevil is offline
<<<Alcyone
The buzz is probably caused by the exhaust shrouds vibrating. I know it's getting to be very annoying on my '92 Ebony.
I'm thinking about trying to remove mine, then I'll just have to stop parking on dry grass.
Dan
Old 04-29-2006, 02:00 PM
Suby Fan's Avatar
Dan
not this one it is coming from the 2nd cat. i know it for a fact I had it on a lift with a friend bringing it up to the right RPM and it buzzed right from there and all my exaust shrouds are in perfect shape and have been hammer tested.. by the way are they really needed? what happens if they are removed?
Old 04-29-2006, 02:15 PM
It's Just Eric's Avatar
Missing in action
Well, their pourpose is to make it as annoying as possible to remove the exhaust. Do yourself a favor and remove all the heat sheilding , minus the one on the main cat.
Oh, and a secondary thing is to prevent any kind of grass or leaves from catching on fire. Because lets face it..after a long drive, EVERYONE parks on a large heap of leaves
But seriously, if your planning on being under the car more than a year, youd be better off removing them.
R.I.P Cool Signature.
Old 04-29-2006, 07:21 PM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
i removed all the shildong on mine..... no probs
The buz maybe comin from here:
If this is not the problem, id bash the crap out of the cat with a hammer, then id drill holes in it, then id go to en exaust palce and get it fixed or replaced
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 04-29-2006, 08:26 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Internal
Some of them do buzz from the inside and it can be very annoying. A year or so ago there was a thread on here where a member cut it open and did a fix on it and then welded it closed.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
(+6 with other members of the family)
FREEDOM IS NOT FREE
Old 04-29-2006, 09:36 PM
Green1995SVX
I think you guys are thinking of the primary muffler buzz, not the secondary cat.
Mike
Old 04-29-2006, 09:37 PM
Green1995SVX
Use this diagram for proper terms:
Old 04-29-2006, 09:51 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Primary Muffler, aka "Stock Resonator"
FYI - no one should be seriously considering cutting open a catalitic convertor - lots of nasty heavy metal in there that has been know to cause cancer. You're better off just replacing them with high flow convertors now on the market....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-30-2006, 03:39 AM
-JJ-'s Avatar
Endangered Species
Mike
yep thats what i was thinking of
Old 04-30-2006, 07:47 AM
curly2k3's Avatar
curly2k3 curly2k3 is offline
Own'eded
Send a message via AIM to curly2k3 Send a message via MSN to curly2k3
2-5 are going to be gone on my soon hopefully, then a turbo install
98 Impreza Wago-O-Doom & Datsun Roadsters
Old 04-30-2006, 08:11 AM
lhopp77's Avatar
Clarification
I should clarify my somewhat ambiguous post. I do not advocate cutting open the catalytic converter. I was actually referring to the resonator. The catalytic converter has rarely been a problematic noise maker. It is nearly always the resonator that developes the tinny sounding buzz and is the one that the member on here had a fix for opening it and welding in an interior piece and then closing it. Another option, of course is to simple cut out the resonator and replace with a straight piece of exhaust pipe.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 04-30-2006, 09:26 AM
Crusader's Avatar
Crusader Crusader is offline
$13000 and counting...
Send a message via AIM to Crusader Send a message via MSN to Crusader Send a message via Yahoo to Crusader
the sound from my '92 got so bad I couldn't stand it... I took it to a muffler shop and they replaced my resonator with a generic "import resonator" worked well didn't change the sound or performance to my knowlede, and only cost about $85
Old 04-30-2006, 12:29 PM
Suby Fan's Avatar
yeah its my resanator thats buzzing.... im going to replace it as soon as i can find a welder
