Old 11-10-2005, 07:31 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Arrow Timing Belt Change Interval
When is the timing belt supposed to be changed in an SVX. For example, 6 years or 80k miles whichever comes first. Also, what other parts do you replace when doing the belt. Water Pump, cam seals, crank seals, etc. What belt should one use, original subaru, Napa, etc.
Old 11-10-2005, 11:06 PM
Here is the link to the maintenance schedule. This should answer your questions on intervals.
Old 11-11-2005, 06:59 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Is the maintenance interval Subaru recommends for engine oil changes truly 7,500 miles?
2006 Steel Gray WRX TR (sold)
Old 11-11-2005, 07:25 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Hmm, it says to check the wheelbearing lubricant at 60,000 miles.
Is that were we could be going wrong?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-11-2005, 07:52 AM
mbtoloczko's Avatar
sans SVX
You should be able to go 100k miles before changing the t-belt. Water pump (incl gasket), thermostat, cam seals, and crank seal are all good to replace while you've got the front of the engine apart. Oil pump shouldn't need replacing. Inspect all the t-belt idlers and replace if the bearings in any appear to be worn. This would also be a good time to flush the entire cooling system and replace with fresh coolant. New radiator hoses would be a good idea too. If you have a leaky power steering system, this would also be a good time to replace any leaky PS hoses and gaskets (because you'll probably have the radiator out and this makes it easier to get access to the hoses).
Mychailo
Visit my locker
Old 11-11-2005, 08:12 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Read you're manual there boy (or sorry forgot you were from the sticks... Have it read to ya) It goes something like this 7500 miles for the oil change unless you drive 1. Short distances, 2. In congested traffic or through traffic lights, 3. On dusty roads. Which unless you live in the midwest sticks and only drive on the highway I think that pretty much covers everybody here then you should change it every 3750. I know this has been Subaru's recommendation at least through the EA-81 engine series (early 80s) and probably even earlier.
Old 11-11-2005, 09:32 AM
Don't shoot the messenger - I only posted the link!!!!
Chike
You need to change your oil more often so that you can oil the road out in front of your house so it isn't as dusty.
