#47
no Liability |
#48
Hi there, so car has been checked and it is little bit complicated.
It is for sure that part of the problem is right CV joint (will replace both sides). The other part of the problem is that it seems there is bad central bearing on prop. shaft or whole connection of both prop. shaft parts, maybe even bearing at the rear diff side. Too much things to check, keep posting results. Petr
Petr "It is never bad enough, it could always be worse" |
#49
Umm. Get new front shafts and plan on buying a new diff.... When you plug the fuse in, it makes it FWD not RWD. Also, please remember this is a family site so no profanities, just relax, freaking out on the people here will not do anything but get you more angry when the replies stop.
Tom |
#50
I tend to not reply or not even read posts with vague titles (please help!) instead of descriptive titles and when the ALL CAPS and bold letters start rolling in. 92awdsvx - your picture has been removed since you ignored Todd's request to remove the profanity.
