Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 06-14-2005, 02:00 PM
KCROGUEDOG
Originally Posted by Weebitob
I know this might be a dumn question but does the sealant help issolate the intake cone from engine heat, or is the intake itself sticking far enough out so it wouldn't be too much of an issue, or is it always?
no the sealent is for in the fender to connect the stock piece of resinator going thru the hole the the new tube with intake head on it. i used sealent to hold the two pieces together. do to the fact the stock piece is to hard to use a hoes clamp on. nothing to do issolation but it is far enough away from bay heat is not an issue.
Old 06-18-2005, 05:48 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
How much different does this sound than perhaps the stock airbox with K&N and Intake resonator removed....because I have that combination and it is quite deep and loud compared to stock. I can't imagine that it would be that different with the exception that the intake element is cone, resulting in more surface area?
-Andrew
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 06-19-2005, 12:07 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
id say as much as a diference between the cone filter and the k&n as the K&N had over stock. it relocates the sound and without the filter housing their is nothing to muffel it.
oh an other note its a damn good thing i got dayle's filter. a return hose for my pwr stearing exploded and tranny fluid went all over the engine bay. if i haden't relocated my intake tranny fluid would have gotten all over my maf.
Old 06-19-2005, 02:29 PM
KCROGUEDOG
i can hear a deep vacuum when i slam on the gas it sounds awsome. way better than just cutting the resinator. that gave me a piter patter sound. it sounded ok at the time but the intake i got now is a big improvement.
