Old 05-19-2005, 07:57 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Send a message via AIM to SVXer95
(IMG)http://www.subaru-svx.net/photos/fil...26522s.JPG/IMG)
Parethesis used so you can see the code. Brackets are used.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
80k miles. MBC + Chips. Relatively Stock
Old 05-19-2005, 05:39 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Many Thanks
SVXer95:
thanks much.
Old 05-28-2005, 10:00 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
My black car:
17x7 Ace WR20s Gold 17lbs a wheel
with 235-40-17 tires (cheaper Lee tires) surprisingly
smooth, nice tires for as cheap as they were.
Im using hubrings supplied by the company and get
zero vibrations up to and over 100....
You may just need hubrings, the place you got your
rims from should be able to get them for you cheap.
Or you just have a wheel or tire a little out of round.
In selling wheels for over 15 yrs, it wouldnt surprise me.
Even with my 18s and 19s on my other cars I have no issues.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Display Modes
