Old 04-21-2005, 09:59 AM
svxsubaru1's Avatar
svxsubaru1 svxsubaru1 is offline
Help my use Mr dyno.
Well one of my friends has a Mr. dyno and i am having problems setting it up. I know how to get around the menu, but i am having problems changing settings that are already there. For example changing the tempurture settings i can get to it, but i don't know how to change the settings. I know a couple of you have set them up for the SVX and are wondering if you would know. Thanks
Old 04-21-2005, 10:40 AM
mbtoloczko's Avatar
sans SVX
I always need to have the manual for it when I use it. Do you have the manual handy?
Mychailo
Visit my locker
Old 04-21-2005, 11:32 PM
svxsubaru1's Avatar
I do, i get every thing how to navigate, how to use functions, but it does not say how to change a value in it, thats the only problem i have.
Old 04-22-2005, 08:44 AM
mbtoloczko's Avatar
sans SVX
Once you have the value that you want, you press the "down-left" arrow key. You can press it one more time to review the value you entered. Press it yet again to get back to the menu.
Mychailo
Visit my locker
Old 04-22-2005, 09:32 AM
svxsubaru1's Avatar
I know how to accept a value, i just don't know how to change a value. For exapamle i dont know how to cahnge the tempurture settings from 50 deggres to 60 deggres.
Old 04-22-2005, 11:23 AM
mbtoloczko's Avatar
sans SVX
I assume you found the "DegF" sign on the Mr. Dyno display. Then press the "return" button once. The current temperature will appear. Press the "up/down" arrows to adjust the temperature. Then press return after you reach the temperature that you want.
Mychailo
Visit my locker
