Old 02-24-2002, 06:34 AM
Dgf
Steering rack leak? 92 LSL
My steering rack and lines are completely wet with fluid. Where do I start to look for leaks?
I haven't driven the car much (still fixing things since I bought it),
so I don't know how fast the power steering fluid level goes down.
It doesn't look like fun to change the rack and of course it is expensive to buy a new one.
Any help is greatly appreciated!
Old 02-24-2002, 09:02 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Check to make sure that it isn't your tranny cooler lines leaking on top of the steering, it was a common item on '92s. The factory has a TSB and a hose kit to repair.
Beav
Old 02-27-2002, 02:20 PM
TonyShaleUK
Steering rack replacement
If you need a replacement rack, I had a second hand rack put in a couple of weeks ago. I tried myself - took 5 hours to dismantle and put back together, as I couldn't get the rack out. My local garage did the job - had to drop the subframe to get the valve block clear. Took them 4 hours.
Old 02-27-2002, 10:29 PM
gl1674 gl1674 is offline
Check the hoses - the return line tends to leak. Also you may have leakage from the engine cam covers - make sure the
liquid is ATF (reddish in color and smells like ATF)
The steering rack can be removed without removing the subframe.
I would not recommend doing it yourself though. The toughest part is to disconnect tie rods - you need a proper tool and a high quality one.
