dash light for e-brake
the dash light for the e-brake ("BRAKE" in red) stays on even if the e-brake is not set. it either refuses to go off or goes off and then re-lights after driving a short way. i've even left the car in the garage with the e-brake off, started the car, driven off and had the dash light come on by itself. suggestions? anyone else have / had gremlins with the dash light for the e-brake? thx in advance. (the '97 outback is doing the same thing...)
Open the brake fluid resevoir cap and close it. The light should go away. Check the brake fluid level as well.
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
This seems to happen often (try a search). Most people usually add a few drops of brake fluid and the light goes away.
Brake light in dash
Hi everyone, I came across this somewhere. I always added brake fluid when I checked and it was low, with out a light. I read that this is bad because if you would let it go, when it did send a signal to turn on the warning light it was really telling you that the pads had worn enough to cause the fluid leval to go down. So this is really teling you to check your pads when the check brakes comes on. It takes a lot of will power to not "top up" the brake fluid reservoir. Take care, BOBB
Even in the owners manual it says a brake light in the dash indicates low fluid...i dont think it would appear if your pads were low.
good thread. i just started having this same issue. now i won't have to search for my own fix.
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty - Sold 07/31/2011 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
Light
Hi soobiesvx93, That was my point. As the pads wear down, the fluid goes to make up for the pad wear. So when the pads have worn down enough to set off the check light you might need new pads. When you put new pads you will push the fluid back into the reservoir and turning off the light. Take care, BOBB
Re: Light
