stock tire on a fwd, 225/50/16, is 24.86 tall (when new).=7730.507 ft/min, or1.464111 miles a minute, or 87.8466 mph? 3050 rpm, 0.694 od, 4394.8126 pinion rpm, if 4.11 gears, now its 1069.2974 axle rpm, 24.86" tall tire, now 6959.3373 ft/min, or1.3180563 miles a minute, or 79.083 mph? It sounds like you have 4.11s. Welcome to the G.T. club.
Subaru Factory Service Manual Brake Band adjustment
Quoted from page 111;
"1. Brake Band If the following abnormal shifting conditions are noted in a road test, the brake band must be adjusted. Impropper brake band clearances and their symptoms clearance 1 "Too wide";Upshift from 1st directly 3rd gear occurs. clearance 2 "Wide". Engine rpm increases abruptly while upshifting from 1st to 2nd gear, or 3rd to 4th gear. clearance 2 "wide" . Time lag of at least one second occurs during kickdown operation from 3rd to 2nd gear. clearance 3 "Small" . "Braking" symptom occurs while upshifting from 2nd to 3rd gear. clearance 4 "Too small" Upshifts from 2nd to 4th gear and downshifts from 4th to 2nd gear occur repeatedly. Adjustment of the adjusting screw. 1) Using a socket wrench, immobilize the end of the of the 7mm screw projecting on the left side of the transmission case, and loosen the nut with a double end wrench. In the case of occurance 1) and 2) mentioned previously, preform the adjustment by loosening or tightening the nut within a range of 3/4 turn from this state. tool# 398603610, tool name SOCKET WRENCH Do not loosen excessively; otherwise, the band strut on the servo piston will drop off. 2) In the case of the occcurance of problems 1 and 4 mentioned previously, perform the adjustment as follows: Adjusting procedure: Tighten the screw to 9 N.M(0.9kg-m, 6.5 ft-lb) torque, then back off three turns. Do not tighten the adjustment screw with an excessively large torque. 3) With the adjusting screw immobilized, tighten the lock nut to 25-28 N.M (2.5-2.9 kg-m, 18-21 ft-lb) torque." All of this is strait from the book.
