Old 01-23-2002, 02:23 PM
eclique eclique is offline
Send a message via AIM to eclique Send a message via Yahoo to eclique
windows stopped working
I have the service manuals (200 bucks with shipping) and am not an electrical schematic wizard. Manual suggests bad ground, bad #15 10amp fuse and on and on. I was just wondering if someone knew where the relay or if there is one a reset breaker for those. I would be grateful for any input or similar experiences and resolve.
Thanks Mike alias eclique
Old 01-23-2002, 03:26 PM
svxter's Avatar
svxter svxter is offline
This account is scheduled to be deleted for inactivity
Send a message via Yahoo to svxter
Can you hear the motor run when you push the button? The most common window failure is the breaking of a little plastic clip that attaches the winder cable to the glass itself. That breaks, the window don't work. It will generally slide down into the door, too. That describe your situation?
bill
Green 95 SVX - Cleo
Green 97 Outback - Maxine
Red F-150 Extended Cab Long Bed - Big Boy
Even the best monkey sometimes drops his banana.
Old 01-23-2002, 03:45 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Windows stopped working? Try pressing the control+alt+delete buttons at the same time. It will re-boot your computer and you can start all over again. That should cure any problems with windows . . . for the moment, but you may want to run scandisk and then, defrag the hard drive. which sometimes . . . . . . . just a second someone's tapping me on the shoulder . . .
Oh, sorry -- you meant the windows on your SVX. Do you mean to say that ALL of your windows have stopped working? I've never heard of that before. That would have to be a bad fuse or a short. What happened when you discovered they weren't working? Were you trying to lower the windows and "nothing at all" happened. OR, did you try to lower the window and you heard it "try" then quit? OR, do you hear the motor running (like Bill said) on ONE window, but all the others are fine? We'll need a little more info before we can be of much assistance.
Randy Johnson
Mike Davis -- at Reading VI
Old 01-23-2002, 04:04 PM
RE:Windows
I tried the alt control del but I lost my connection!
When I bought the 93 svx for 1650 1890 off the auto auction floor some jerk trying to detail the car turned a fire hose on the succer I guess to get rid of tobacco smell. I guess a short but under the drivers seat? I used the windows just fine for a couple of days then nothing the next time I tried nothing happened and the sun roof is gone as well.
mike
Old 01-23-2002, 04:34 PM
svxter's Avatar
Randy's point is well taken. If ALL the windows are kaput, I'd look at the fuse. If replacing it either doesn't fix it, or only provides a short term fix, I'd guess you have a short in the wiring somewhere. Let's hope it's a fuse. Your service manual should be able to inform you as to the fuse, its location and size. If it's only ONE window, usually the driver's side, the clip would be my prime suspect.
bill
Green 95 SVX - Cleo
Old 01-23-2002, 04:44 PM
Thanks everybody. You are all like the guy at the bar telling me where the door I came in is at.
"Thanks again." he said with a grateful grin.
Old 01-23-2002, 07:17 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Smile O.K., O.K....
It looks like there's both a circuit breaker and a relay for both the power windows and sunroof either underneath or behind the driver's seat. Automtoive cb's are normally auto-resetting. I'd guess more along the line of the relay being bad, but you need to check them both.
Go to my locker and check out the diagrams, box F shows the cb and relay (for what it's worth) and the conn pic gives a rough approx. of location in car.
Beav
Old 01-23-2002, 07:19 PM
Beav's Avatar
Not as old as Randy
Ooops - sorry
What you're looking for in the conn pic are connectors R43 & R44
Old 01-23-2002, 08:21 PM
Hey beav thanks
I guess I need to take the seat out to get to that stuff. I spent an hour playing contortionist and didn't make much headway. The bracket holding the pw circuit spins around on what ever it is connected to I wonder if it is a ground point and failed there?
Guess I'll keep trin. And really THANKS for the responce.
Mike
Old 01-23-2002, 11:37 PM
lamboman1pa
Hey Mike,
When my windows stopped working I got lucky. I took the drivers side door panel off and found the switch assembly connector had separated from the wire harness. Wish you the same luck.
Later, John
Old 01-24-2002, 12:20 AM
Thanks lamboman1pa
I had read a --all post related to windows and have taken both door panels off. Replaced the door and rear speakers with Xplods sweet. Added 2 internal amped kenwoods 8in. subs. Really great sound but cant roll down the windows to share the sounds. LOL
Thanks for the heads up.
Old 01-24-2002, 12:06 PM
Aredubjay's Avatar
Hey, eclique. Some of us have been in the bar so long that we have to keep telling other people in order to remind ourselves. Belly up, and good luck.
Randy Johnson
Old 01-24-2002, 12:39 PM
rufus's Avatar
rufus rufus is offline
I look like Gordon
Randy-
You really should stop talking about Larry and Ron behind their backs like that.
-Mike
I'll have a kilt-squeezins and soda, on the rocks, thanks.
First the smiles, then the lies. Last comes gunfire.
Old 01-24-2002, 01:04 PM
Aredubjay's Avatar
Originally posted by rufus
Randy-
-Mike
I'd have no problems talking about them in front of their backs.
Randy Johnson
Old 01-24-2002, 09:18 PM
Ron Mummert Ron Mummert is offline
Invisible avatar
Send a message via AIM to Ron Mummert Send a message via Yahoo to Ron Mummert
Wink
I just wish my back were in front. Great abs! Nah, ribs.
Ron.
Good s**t happened. 69 was worth the wait.
'92 stock semi-pristine ebony - 160K
'96 Grand Caravan - 240K
'01 Miata SE - 79K
'07 Chrysler Pacifica - 60k - future money pit.
