Awd
Hey guys
Anyone ever have a problem with thier SVX tranny where it feels like the rear wheels aren't being driven and the front wheels will spin excessively?
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
i dont know much about this but ive heard of people putting a fuse in the FWD box in the fuse box in the engine compartment and it made them spin excessively
1994 Pearl LS Black top ( The Penguin) "was" The only man alive who drives a "Suba SSV".......according to my insurance company ***sold*** "was" The Only Subaru Svx Owner in Laredo Tx., or maybe atleast only owner registered here.... http://www.cardomain.com/id/phoenix_3737 |
Re: Awd
You could check that the FWD fuse is not inserted in the under hood fuse box. The Transfer clutch housing can be removed from the back of the box to replace the C solenoid valve assemble and the clutch plates. Till you fix it ,DON'T SPIN THE FRONT WHEELS, IT CAN CAUSE THE FRONT DIFF TO BREAK. Harvey.
Duty Solenoid C
I have no space in the fusebox for a fwd fuse because I converted this car from FWD. I had to custom make the harness for the AT OIL TEMP and FWD lights and the FWD switch. I Have a replacement duty solenoid C, I just haven't put it in yet. I hope it will fix it tho, it was a 90 dollar part. The TCU should detect a siezure of solenoid c according to the subaru RM. anyone out there replaced duty solenoid c and/or the transfer control valve?
NiftySVX
replacing the solenoid isn't overly hard, just time consuming - have to pull the driveshaft and take off the transfer case housing - careful the wires aren't too long. The search button is your friend - try "solenoid and transfer".
But, have you done a pressure test on the AWD section? It could be the solenoid is working fine, but the plates are worn over time - and worsened by differing tire sizes/pressures not set correctly. if you have a good internet connection download the tranny manual in my locker. part 2 has disassembly instructions, part 3 has assembly. BTW, I have not personally done this repair so your use of the words & pics in the manual is at your own risk. |
Re: Duty Solenoid C
AWD
I do have an awd TCU and I have tested the transfer pressure.
It won't be the first time I have had a 4EAT apart, and I own the service manuals. The transfer pressure is 0 untill wheel slippage occurs, then it jumps up and then falls back to zero. I was wondering if the MP-T was worn. Just curious if anyone else has had a similar issue. Thanks, NiftySVX
Thread Tools | |
Display Modes | |
