question about 18' rims
I want to get these rims but i want to make sure they will fit ok.
its 5/114 with a 45mm offset. anyone have this size rim ? does it ever scrape or rub( with or without people in the car? . I want bigger rims but not sure if 18s are to big. thanks |
This wheel offset calculator courtesy of "lee"
http://toy4two.home.mindspring.com/offset.html |
Those wheels should work as long as there not too wide . I run 18 X 7 wheels with 42mm offset and I have no rubing.
fitment
ok heres what i got,
anyone know if this will work??? thanks guys The clearance from stut housing to the inside of the wheel will be 4mm MORE The outside edge of the wheel will EXTEND an extra 16mm |
Sounds like those wheels will rub on the rear fender.
Mine are 7mm closer then stock and there only about 5mm from the fender.
laryiii has a tire calculator in his locker. http://www.subaru-svx.net/photos/fil...yIII/14768.xls |
Re: fitment
I gaurantee you that 18 foot diameter wheels will not fit...
.Karl. Southwest members, click here to check in!CA,NV,AZ,UT,NM,OR,CO Wanted...your busted SVX! Watch out Earl, I'm comin to getchya Return of the Pissed Platypus! X2 My dream (other than a pearlie) 1.8 SVXi and a laguna blue spoiler...somewhere I decided to quit drinking, but I didn't like it so I quit not drinking. |
Ok I found rims I want but I have a new question.
These are 18 x 7.5 with 40 mm offset. sound ok? and the guy said They come with 12mm x 1.5" lugs. I would have to buy the 12mmx 1.25 lugs locally he said. Will that work ok? are hey alot of $$$$? thanks guys!!! |
I got this from the tire calculator on those above rims I want.
any suggestions? The clearance from stut housing to the inside of the wheel will be 9mm MORE The outside edge of the wheel will EXTEND an extra 21mm |
Rims on hold
Thanks for all your help people!!!!
But Now I have to wait till spring to get my rims or my wife will say "no more punany for you" |
Re: Rims on hold
